transmission
Old Apr 17, 2016 | 08:29 AM
Rusty Odom's Avatar
Rusty Odom
Default transmission
I have a 1996 dodge ram 1500 4x4 and the reverse quick working in it and now 1st hear is starting to pull out real slow and I have looked every where for another one and can't find one for it does any one know what other transmissions will interchange with this one
Old Apr 17, 2016 | 08:45 AM
Automatic? If so, thats a 46RE, and was used from 96 on in the 2nd gen trucks. There were some minor changes in 2000, (or was it 99?) model year, and the electronics are different, but, can be swapped out for the 'right stuff' for your truck. Pretty much, any truck with a V-8, and auto, (and 4x4) will bolt right in, and hook right up. Doesn't matter what weight rating it was.
Now, granted, the last of these trucks rolled off the assembly line 15 years ago..... so they are probably getting scarce even in the junkyards...... If you can't find one, then a rebuild might be your only option.
Old Apr 17, 2016 | 08:55 AM
Rusty Odom's Avatar
Rusty Odom
Yes it's an automatic the pulling gear in it is starting to pull out slow but gains momentum quickly and the reverse is completely out of it but the rest of the gears are changing and driving great
Old Apr 17, 2016 | 09:18 AM
When's the last time you have a fluid/filter change, and adjust the bands? Might be all it needs.....
Old Apr 17, 2016 | 09:22 AM
Rusty Odom's Avatar
Rusty Odom
I changed the fluids in it bout 2 or 3 weeks ago and I have not adjusted the bands in it cause to be honest i don't really kno how to do it
Old Apr 17, 2016 | 09:27 AM
It's actually pretty easy..... Just need a torque wrench that is accurate at 72 INCH pounds. (you should be able to rent one.) Procedure is in the service manual, which you can download from here. (and I highly recommend just downloading it, it saving it to your local harddrive... loads a lot faster that way.)
Old Apr 17, 2016 | 09:30 AM
Rusty Odom's Avatar
Rusty Odom
Ok I'll give that a try then I have been told that might be all thts wrong but I never knew how to do it but I'll give that a try and I hope that fixes it thank you
Old Apr 17, 2016 | 10:29 AM
Good Luck, and let us know what happens.
