NP241DLD to NP242D
Old May 3, 2016 | 04:14 PM
Bushwookie's Avatar
Bushwookie
Yep it does, the teeth are cut similar so once it lines up, it drops right in. Originally i was going to swap just the input gears, but noticed the differences in planets. Im not sure if it makes a difference in the strength or not, but we'll see.
Considering the strengths of the two, if the 242 holds up to a 300hp cummins, then I have no doubts that it will hold against a 300hp magnum.
Old May 3, 2016 | 04:21 PM
I am a big fan of overkill when it comes to strength of driveline parts.....
Old May 3, 2016 | 08:50 PM
Spillage's Avatar
Spillage
The more planetary gears, the higher the torque capacity.
However, higher torque rated TC's usually have the heavier input and output shafts... AND wider chains.
Old May 3, 2016 | 11:53 PM
Bushwookie's Avatar
Bushwookie
I wanted to swap everything that I could over, but the chain wouldnt fit because of the spacing on the sprockets.
Old May 4, 2016 | 09:16 AM
The War Wagon's Avatar
The War Wagon
Talking
The CAD fix is IN! Posi-Lok for the win.
Manual hubs, and you can delete the cable!
Old May 4, 2016 | 09:05 PM
frankie_b_jr's Avatar
frankie_b_jr
Originally Posted by Bushwookie
A slight issue, but I've found a way to use the ABS sensor input.
Mind if I ask how? I haven't had a speedometer for years because of various issues, then swapping to a 98 2500 undercarriage.
Old May 5, 2016 | 02:42 PM
Bushwookie's Avatar
Bushwookie
This link below helped show me how to use the ABS sensor signal.
http://www.dieseltruckresource.com/f...ssible-296592/
This is another way, but the concept is still the same.
http://www.dieseltruckresource.com/f...er-fix-295107/
Old May 5, 2016 | 09:39 PM
frankie_b_jr
So did you just buy This box and tie it into the tone ring, or did you add a sensor, or?? Just trying to understand how you did it.
Old May 11, 2016 | 02:16 PM
Bushwookie's Avatar
Bushwookie
I bought the box and tied it into the vss wire from the abs sensor in the diff.
Old May 12, 2016 | 11:34 PM
frankie_b_jr
Thank you. Great write up for the t-case. Maybe a mod can parse it down and add it to the DIY sticky.
