ABS and Brake Lights
Old Jul 1, 2016 | 08:15 PM
Ham Bone's Avatar
Ham Bone
Default ABS and Brake Lights
Failed inspection cuz my abs and brake light where both on. I need to get one to go off. Any ideas?
In the winter, driving in the snow and when I cut it off my abs module wouldn't quit pumping so I pulled the fuse. Am I looking at a new module?
Old Jul 1, 2016 | 09:27 PM
Get codes read. May be as simple as replacing the rear wheel speed sensor.
Old Jul 1, 2016 | 10:38 PM
Ham Bone's Avatar
Ham Bone
Well I just replaced the speed sensor. didn't seem to to make a differenence.
Old Jul 2, 2016 | 09:51 AM
Need to know what it's whining about then. With 4wal, there are three sensors...... any one of which could cause the same problems.
Old Jul 2, 2016 | 12:32 PM
Ham Bone's Avatar
Ham Bone
It threw codes for all of them.
Old Jul 2, 2016 | 02:23 PM
All of them????? Are they getting power? (5 volts, methinks)
Old Jul 2, 2016 | 05:13 PM
Ham Bone's Avatar
Ham Bone
I haven't checked that. But my abs module stays pumping unless I pull the fuse. Whether the trucks on or off.
Well, the front left and right. And the rear center.
Old Jul 2, 2016 | 05:59 PM
That's all of 'em.
It still runs in park, with your foot off the brake? That's just odd. Anything in the service manual for your symptoms?
Old Jul 3, 2016 | 03:22 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb
The brake indicator gives an indication to the vehicle
operator when the parking brake is applied, or
when there are certain brake hydraulic system malfunctions.
The CAB then sends the proper lamp-on or lamp-off messages to the instrument cluster. If the CAB sends a lamp-on message after the bulb test, it indicates that the CAB has detected a brake hydraulic system malfunction and/or that the ABS system has become inoperative
Sooo...the ABS system turns both lights on when it fails.
Old Jul 4, 2016 | 09:54 AM
Ham Bone's Avatar
Ham Bone
That's all of 'em.
Yep. It is odd. And I haven't found anything.... yet.
