No power to coil
Old Jul 12, 2016 | 08:25 PM
Scott Dimauro's Avatar
Scott Dimauro
every where i call does not sell it separtly they all say got to buy the bundle package ,,,,,dirtribor cap roter cam sensor where do i find it separtly
Old Jul 12, 2016 | 08:54 PM
Parts Geek has em. Listed as pickup coil. Under 50 bucks. (may also be shipping charges too....)
autopartswarehouse has 'em too... (bit more expensive though.)
Old Jul 12, 2016 | 11:00 PM
frankie_b_jr's Avatar
frankie_b_jr
MP832 is the napa number for it. Here is a link to the napa website for it:
"Pick Up Coil" aka: cam sensor
Old Jul 15, 2016 | 09:46 AM
Scott Dimauro
Angry
went to get ingition pick up still dont want to start so now i have new pick up,, coil, cap, roter, crank sensor,,,,, all fuses, good relays good,, seams like in time as far as what i see out side,,, have 12 volts to coil,, injectors,, pick up ,, only code shows up is p-0320 still i know what code mean gonna ckeck for wire shorts any more suggestions
Old Jul 15, 2016 | 10:17 AM
How is fuel pressure?
Old Jul 15, 2016 | 03:50 PM
Scott Dimauro
Question Sparkin problem 2000 ram 1500
I think it jumped time its sparks every few turns,,, has new plugs,, wire,, cap,, roter,, coil,, crank sensor,, cam sensor,, no codes show up
Old Jul 15, 2016 | 06:46 PM
Pull the distributor cap, and turn the crank so number one is at tdc. (top dead center) Where is the rotor pointing?
Old Jul 16, 2016 | 03:53 PM
Scott Dimauro
its pointin at number 1 every 10 or so revalation it sparks i know it should spark all the time,,,, roter points at 1,,, marks line up hormonic balancer lines up but that dont mean the timein gears and chain do im pretty mechanically incline somethingis out of time some where
Old Jul 16, 2016 | 04:17 PM
Distributor is driven off the camshaft, which is run by the timing chain and gears. If everything lines up, that isn't the problem. If you are only getting intermittent spark, THAT is a problem.
Old Jul 16, 2016 | 11:25 PM
Scott Dimauro
ok so what do u think is the problem then caue im lost and every 1 i talked to says its out of time i really dont wanna tear the front of my moter apart if i dont have to
