Need help with my 2000
Old Jul 17, 2016 | 02:29 PM
richey5's Avatar
richey5
Default Need help with my 2000
OK guys I got a 2000 Dodge Ram with the 5.9. I just got the trans rebuilt 100 miles ago and now my new torque converter is already going out. But besides that the other day I left it idling while I was waiting on a guy and smelt horrible smell like carbon monoxide or something from exhaust. Developed a slight miss. Only noticeable during idle. But when I got up to 60mph my truck started shaking. Could the shaking be from the torque converter or do u think I need plugs and that is causing all of it? Still pretty powerful. The torque converter is just whining pretty good. Could it be the MAF? Or would y'all lean more towards 02 or clogged cat.
Old Jul 17, 2016 | 02:57 PM
dbbd1's Avatar
dbbd1
Always the first question...
How's your plenum?
Old Jul 17, 2016 | 04:35 PM
^What he said.
Probably blown plenum, which is fouling your plugs, clogging your cat, and inducing your misfire. If turning off O/D at 60 reduces the shaking dramatically, it's more likely an engine miss, rather than a trans problem.
Where did you have your trans rebuilt? Any warranty on it?
Old Jul 18, 2016 | 01:04 AM
richey5's Avatar
richey5
^What he said.
Plenum has already been changed. Came with year warranty. He is fixing the converter on it Tuesday. When your at an idle u have to roll window down so u can breathe with all the fumes. But only does it every now and then. No codes thrown. I'm gonna check plugs and wires then move onto the next.
Old Jul 18, 2016 | 08:57 AM
Do you have exhaust leaks?? What does it smell like?
Old Jul 18, 2016 | 07:49 PM
richey5's Avatar
richey5
That's what I'm trying to figure out lol. I think I figured it out. It's an o2 sensor almost positive. Exhaust smells pitiful. Gives u headaches but it don't do it all the time only when it wants too.
Old Jul 19, 2016 | 09:23 AM
If you are getting exhaust in the cab, time to find where it's coming from.
Old Jul 19, 2016 | 05:46 PM
UnregisteredUser's Avatar
UnregisteredUser
Beats hell out of allowing deferred maintenance to kill!
Old Jul 23, 2016 | 03:05 AM
richey5's Avatar
richey5
Sorry I haven't gotten back on here had a death in family. Anyways my exhaust stops where the cab meets the bed. No turn down just straight out. I found my downstream o2 was bad. Replaced it and I got all the stuff for a tune up just had this little delay
Old Jul 23, 2016 | 09:54 AM
Need to fix your exhaust too.....
