High beams stuck on aftermarket headlights
Old Jul 21, 2016 | 02:43 PM
tot64's Avatar
tot64
Default High beams stuck on aftermarket headlights
Hey guys, I was wondering if anyone had a headlight wiring diagram to make my lights work. I believe they are meant for the sport version with 4 bulbs and mine is a 98 which I believe only has 2. I've looked and looked and can't seem to find a thread with the pictures working
Old Jul 21, 2016 | 03:00 PM
You can download a copy of the 99 service manual from the faq section here.
Old Jul 21, 2016 | 04:09 PM
tot64's Avatar
tot64
I looked at that but i couldn't really tell how to convert to the 4 bulb system to the two, which is what I would have, right? My truck is a 98 sport, which I thought only had two. And I found a thread with someone who had the exact same problem as me(high beams always on) but all the pictures weren't there anymore
Old Jul 21, 2016 | 04:24 PM
Look at the four bulb system. I think you really only need to move one wire to make it work, but, that also depends on what bulbs your are using. 9007's, and 9004's are do believe need to be wired different.
Old Jul 21, 2016 | 07:15 PM
dbbd1's Avatar
dbbd1
So you have a sport but it only has two headlights/bulbs?
Old Jul 21, 2016 | 08:34 PM
Spillage's Avatar
Spillage
Must be early 98 (built before Jun)... 98½ Sport went twin bulb I believe.
Old Jul 23, 2016 | 11:20 AM
tot64's Avatar
tot64
You are correct spillage. Just checked, made May 98. The headlights look like they were made for the truck though, because there is one plug for each light. I'm assuming it was wired wrong from the factory. So any ideas on how to fix them? Should I just try to use the wiring diagram best I can?
Old Jul 23, 2016 | 11:22 AM
What bulbs are you using?
Old Jul 23, 2016 | 01:10 PM
tot64's Avatar
tot64
I just pulled the housing to look. One bulb is a sylvania hb3 9005, other bulb is an h1, not sure of the brand
Old Jul 23, 2016 | 01:48 PM
Buy a pair of 9004 bulbs, they are what comes stock on the truck. Should solve your issues.
