Experience with POR15?
Old Sep 25, 2016 | 09:08 PM
HerpDerp1919's Avatar
HerpDerp1919
Default Experience with POR15?
As i'm swapping my bed, I figured this would be the best time to clean up my frame a bit. I know POR15 is made to go over rusty metal. Nothing rusted through, just surface rust at worst. Ive hit the really scaly and flaky areas with my wire wheel. But a good portion of my frame look like the picture below. Would POR15 still stick to that?
Old Sep 25, 2016 | 09:23 PM
adukart's Avatar
adukart
As long as you go over both sides your fine.
Old Sep 25, 2016 | 09:26 PM
AtomicDog's Avatar
AtomicDog
I use this product on my truck - works very nicely - zero-rust.com/
Old Sep 25, 2016 | 09:36 PM
HerpDerp1919
Alright, cool.
AtomicDog, I already have 3/4 of a gallon of POR15 from my other project
Old Sep 25, 2016 | 11:16 PM
AtomicDog's Avatar
AtomicDog
Then POR15 will be your choice, for sure. Understand you want to use what you have.
Old Sep 26, 2016 | 01:29 PM
MedicNathan's Avatar
MedicNathan
What kind of life are you getting from it. I used it on my rear bumper and the thing started rusting again after about 3 years.
Old Sep 26, 2016 | 09:19 PM
HerpDerp1919
Did you do the inside of the bumper as well?
Old Sep 27, 2016 | 12:26 PM
Yes. If you leave exposed metal, it will rust from that side.......
Old Sep 27, 2016 | 06:41 PM
Moparite's Avatar
Moparite
"POR-15® Rust Preventive Coating"
You want a rust converter/neutralizer. There are several products that will do this then prime and finish paint if that's what you where planning. You can get a sand blasting attachment for a pressure washer and take it down to bare metal! I have one of these and they work well. You can rent a pressure washer at any rental place.
Old Sep 27, 2016 | 10:43 PM
HerpDerp1919
I wish I could sandblast. But the cab has to stay on the truck. As of now, I don't have the space, nor time to pull it all apart.
