HELP 😫 1997 Dodge Ram 1500 4x4 sst 5.9 231 d had transfer case
Old Oct 16, 2016 | 05:12 PM
BBBESSIE's Avatar
BBBESSIE
Question HELP 😫 1997 Dodge Ram 1500 4x4 sst 5.9 231 d had transfer case
Found a 231 d hd out of a 1999 1500 ec? Will this bolt right back in mine???
Old Oct 16, 2016 | 05:45 PM
It will bolt right up, but, it *might* be a little bit longer, thus, requiring shortened driveshafts...... Measure it and see.
Welcome to DF!
Old Oct 16, 2016 | 05:54 PM
BBBESSIE's Avatar
BBBESSIE
That was supposed to say 231-d-hd transfer case in mine LOL sorry. Ok could you explain the shorten drive shaft a little more. I am a woman but I am mechanically.... but not ashamed to say and or admit when I don't know something.
Old Oct 16, 2016 | 05:57 PM
BBBESSIE's Avatar
BBBESSIE
Old Oct 16, 2016 | 05:58 PM
If they are both DHDs, it will bolt right in, only difference being the shift pattern. That changed in 98...... Also, the 99 won't have the provision for the VSS (your speedo won't work.) on the output shaft of the t-case.... you really need one from a 94-97.
What's up with the one that's in the truck?
Old Oct 16, 2016 | 06:08 PM
BBBESSIE's Avatar
BBBESSIE
The one I'm looking at was built in 01/99 according to the plate. Last weekend coming home to Talladega I started leaking transmission fluid. Truck still drove even though it was pouring straight out as I was putting it in so I had it towed. Then I got under it and discovered this (will attach pics) According to the mechanic (don't have a really good feeling about him) he said there's nothing wrong with the transmission that I need to replace the plate my rear yoke and my transfer case did not have even a drop of fluid in it.
Old Oct 16, 2016 | 06:38 PM
Is that the t-case? Or the o/d housing?
Old Oct 16, 2016 | 06:40 PM
BBBESSIE's Avatar
BBBESSIE
Overdrive housing
Old Oct 16, 2016 | 07:39 PM
Ouch.
Time for a new trans methinks. That one giving up like that is highly likely to have distributed a fair amount of crap throughout the trans..... You *might* be able to get away with just swapping it out.... but, I wouldn't hold my breath on that.
Also, keep in mind, that there is a BIG spring in there.... and it's possible for that thing to grenade in a major way when you take it apart.....
Old Oct 16, 2016 | 10:34 PM
2bit's Avatar
2bit
Why do you need a transfer case if the overdrive housing is broken? Would you post a few more pics please. There is a snap ring that fails in the tailshaft of the transfer case that can cause major failure. The Transfer Case Saver replaces that snap ring.
