No power on take off
Old Oct 30, 2016 | 11:00 AM
Greginwv's Avatar
Greginwv
Default No power on take off
New owner here just bought a 2001 ram 5.9 magnum last week runs great once you get going. I live over a very steep hill when pulling out from the hill i have to hold it to the floor and it barely goes. On flat ground it goes a little sluggish till about 5 to 10 miles an hour then it will throw you back and go. Ive changed plugs, wires, cap, rotor, IAC,checked map, tbs, looked in tb some oil splatter from pcv changed that didnt see any pooling but couldnt see the corners. Thought maybe taking off in wrong gear but counted shifts 1 2 3 3L with od off so they are all there, punched cat. Im out of ideas help please.
Old Oct 30, 2016 | 11:12 AM
Check engine lite on?
What size tires? Any idea what gears in the diff?
2 or 4 wheel drive?
Any history of major engine work??
Welcome to DF!
Old Oct 30, 2016 | 11:15 AM
Greginwv's Avatar
Greginwv
4wd 3.55 gears 285 70 16 tires engine repair history i dont know no lights
Old Oct 30, 2016 | 11:33 AM
Basically 33's, and 3.55 gears... that's part of the problem....
Does it seem any better if you pull the shifter all the way down to first, and try and go?
Old Oct 30, 2016 | 11:35 AM
Greginwv's Avatar
Greginwv
No change when manually shifted
Old Oct 30, 2016 | 11:48 AM
That's interesting..... Check the pcm for a sticker that says "authorized software update". It'll probably be hand written......
Old Oct 30, 2016 | 11:54 AM
dbbd1's Avatar
dbbd1
Does this happen every time or just first thing in the morning (thinking check valve delete)?
Old Oct 30, 2016 | 11:59 AM
Greginwv's Avatar
Greginwv
Happens all the time there is a sticker with a bar code that says authorized software update
Old Oct 30, 2016 | 02:06 PM
44dakota's Avatar
44dakota
[QUOTE=HeyYou;3315818]Basically 33's, and 3.55 gears... that's part of the problem....
QUOTE]
plus the death flash...
