VTSS dodge v10
Old Nov 11, 2016 | 11:12 PM
GB93's Avatar
GB93
Yes it did I drove it 500 miles home when i bought it put around 200 miles on it after I got it home and then all of a sudden drove it and shut it off and it wouldn't start again I lost all communication with my pcm kept saying no bus on odometer and CCD on overhead where the outside temp is displayed put a used pcm in it started up ran for a few hours and i lost it too finally i bought a rebuilt pcm put it in and it fired up and died 3 times and now all it does is crank it will start on starting fluid but injectors aren't firing so the dealership is saying it has something to do with the theft system replaced crank and cam sensors and fuel pump all fuses are good
Old Nov 12, 2016 | 09:57 AM
Sounds more like a failing central timer module.......
Old Nov 12, 2016 | 09:58 AM
GB93's Avatar
GB93
Where's this located ?
in the dash somewhere. Service manual will tell you where its at.
Old Nov 12, 2016 | 10:33 AM
dbbd1's Avatar
dbbd1
It's located in the dash above the drivers right knee.
