VTSS dodge v10
Old Nov 10, 2016 | 04:27 PM
GB93's Avatar
GB93
Default VTSS dodge v10
Took my truck to dealership and re flashed pcm and it still won't start the vtss theft system won't let it get fuel any help?
Old Nov 10, 2016 | 04:30 PM
Bypass it, (for fuel) see if the truck will run.
Not just a bad fuel pump is it?
Old Nov 10, 2016 | 04:32 PM
GB93's Avatar
GB93
New fuel pump will start on starting fluid just won't fire the injectors dealership says the vtss code comes up
Old Nov 11, 2016 | 08:14 AM
What code?
Old Nov 11, 2016 | 09:58 AM
GB93's Avatar
GB93
Idk had the dodge dealership re flash my pcm and they hooked up their scanner and said that the vtss code or something said the reason it won't start is because the theft system won't let it so idk is there a way to by pass it idk I told the dealership to fix it
Old Nov 11, 2016 | 07:07 PM
Did they give you an estimate??? There *should* be a way to bypass, but, I don't know what it is just off hand. (my truck doesn't have it.) If its just programming, and reading a chip in the key, or some such.... its gonna be tricky.
Old Nov 11, 2016 | 07:11 PM
GB93's Avatar
GB93
They said my truck didn't come with it either and when I bought the truck I didn't get the original key they said someone may have changed the steering column ? Idk they are digging into it deeper
Old Nov 11, 2016 | 08:12 PM
Have you ever been able to start it??
Old Nov 11, 2016 | 08:14 PM
GB93's Avatar
GB93
With starting fluid won't let the injectors fire
Old Nov 11, 2016 | 09:02 PM
So as long as you have owned it, it has never started and ran?
There are a fair few codes for the anti-theft system..... really need to find out which one it was. Of course, the dealer is handling it at the moment......
