2001 ram 1500 5.9L NEED HELP!
Old Nov 22, 2016 | 05:33 PM
Tyler21's Avatar
Tyler21
OK i checked those and they are fine nothing wrong with them.
Old Nov 22, 2016 | 06:48 PM
Tyler21's Avatar
Tyler21
OK checked all the plugs and they are all clean nothing broken with them.
Old Nov 22, 2016 | 11:00 PM
Verify you are getting 5v reference signal at the sensor. (since the truck runs, my guess would be "yes".....) Gotta be a bad connection somewhere, pinched wire, corrosion, whatever, bad sensor, (yes, even though its 'new'....) or failing PCM. (rare.)
Old Nov 22, 2016 | 11:02 PM
Tyler21's Avatar
Tyler21
I'm leaning more towards a bad sensor because it's not Mopar. So I think I'm going to try and do that and then make sure it's timed correctly.
Old Nov 23, 2016 | 09:19 AM
Timing isn't adjustable. Turning the distributor only changes injector timing. You get a VERY small range of 'acceptable' on that too. too far in either direction and you get some really strange performance issues. Need a scanner that can read fuel sync to set it properly.
Old Nov 23, 2016 | 09:22 AM
Tyler21's Avatar
Tyler21
Oh I did not know that. Thank you for telling me that before I went and messed something up.
Old Dec 8, 2016 | 07:13 PM
Tyler21's Avatar
Tyler21
Default Thanks for the help!
I replaced the crank sensor with an OEM crank sensor and it fixed all the problems thank you so much!
Old Dec 9, 2016 | 07:43 AM
Awesome.
Enjoy!!
