Governor sensor and bracket
Old Nov 23, 2016 | 02:04 PM
97ramrod1500's Avatar
97ramrod1500
Default Governor sensor and bracket
I am aware that the governor sensor changed in 2000. I swapped a 2001 trans into my 99 and had to swap the sensors. When I swapped them I just swapped the whole aluminum bracket that holds both the governor sensor and solenoid. I will be rebuilding my transmission soon and am wondering if there is any difference in that aluminum bracket and if I can just pull out the 2000/20001 governor sensor and swap in a 96-99 style sensor?
If not I need to find a junk trans I can rob one out of.
Old Nov 24, 2016 | 09:14 AM
The only real difference is the retainer. Everything else is pretty much the same. Also note: The 2000 and up sensor gives a different signal range than the older guys.
Old Nov 24, 2016 | 10:13 AM
97ramrod1500
Yes i found that out the hard way lol so I just need to get my hands on a retainer then.
Anyone have a junk trans laying around they wanna pull one out of? Lol
Old Nov 24, 2016 | 10:35 AM
dbbd1's Avatar
dbbd1
For which year? I'm confused now on which you're going with this...
Old Nov 24, 2016 | 01:39 PM
97ramrod1500
96-99. I swapped a 2001 trans into my truck but had to remove the electronics and governor bracket from the 01 trans and put my parts from my 99 trans into the new one. Now I need a new governor bracket for the 99 trans so I can rebuild it.
Old Nov 24, 2016 | 03:23 PM
dbbd1's Avatar
dbbd1
I will check my attic tomorrow.
