01 Dodge Ram "no bus" problem
Old Nov 29, 2016 | 04:06 PM
Somethin' else is going on there...... not entirely sure what. Try disconnecting the cam sensor as well. (in the distributor. connector should be toward the drivers side.)
Old Aug 28, 2018 | 12:35 PM
Kyle Kiernicki's Avatar
Kyle Kiernicki
I have tried everything listed in this thread, is there any other insight on this problem? When I turn my key on it shows my mileage but 10-15 seconds it then flashes and shows no bus, I’ve unplugged all sensors on the truck I’ve also checked and cleaned all connections for the fuse panel next to the battery and I’ve also cleaned and checked all connections on the pcm. I’m stumped here. Any insight would be great thanks!!
Old Aug 28, 2018 | 12:50 PM
What are you driving?
Old Aug 28, 2018 | 12:52 PM
Kyle Kiernicki
Sorry 2001 Dodge Ram 1500 5.9l laramie
Old Aug 28, 2018 | 02:46 PM
Kyle Kiernicki
Update got the truck running, went about a half mile and it just died, all I did was remove the cap on one of the pcm connections to expose the wires, wiggled some around and plugged it back it and it ran, I tried doing that when it died on me on the road and I got all cluster back but no start, I’m still stumped!!
Old Aug 28, 2018 | 03:40 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Bad wire/plug/PCM/connection is what it sounds like to me
Old Aug 28, 2018 | 06:06 PM
Seconded.
Old Aug 28, 2018 | 08:02 PM
Kyle Kiernicki
Another update, I’ve went through all the wires in all 3 plugs none of them are loose.
i found out that the clips that hold the plugs on are broken on 2 of 3 of the plugs, so I’m narrowing it down to the plugs. Just wish there was an easier fix then zip ties and duct tape!!
Old Aug 28, 2018 | 09:26 PM
Super Glue? (joking.....)
Old Mar 29, 2019 | 10:26 PM
Ricardo Zamora's Avatar
Ricardo Zamora
Default I need help 😭
My truck ran good yesterday and everything but then I tried to turn on the truck yesterday in the night and it didn't start it cranks up but does not start I checked the codes and it shows up the no bus code and it does not start up
