Help with odd engine sound [Video!]
Title says it! You'll hear the weird, almost tick-lick sound (not quite a tick more of a thuck inhale sound xD ) on the passenger side in this video, sound isn't on drivers side. Any ideas what this could be? Haven't done any troubleshooting or diagnosing yet as I'm swamped with work at the moment.
IN OTHER NEWS!!!! The engine swap was a success! Started up on literally the first key turn, and that was on old gas! Sounds pretty damn nice, keeps a steady idle around 650RPM, it drives (except the brakes need bleeding)!
Two links in case one is being funny :P
https://youtu.be/OhDI3jDJr1I
https://www.youtube.com/watch?v=OhDI...ature=youtu.be
Will check that for sure once the exhaust is fully bolted or unbolted. Right now the header is only bolted to the y-pipe on the passenger side, and has an alignment issue on the drivers side, so more or less is unbolted and theres a good gap between the header and the y-pipe. If that wouldnt affect it, its very possible the seal isnt perfect on that side since thats the side we had to weld a stud into place. Its possible we didnt get the sides of the stud smooth enough and is causing a gap. Who knows! Thanks for the tip off on what you think is responsible though, will give a good starting place.
Header gasket is blown out and leaking. Get these gaskets, best ones I've had, better than Felpros.
https://www.summitracing.com/parts/rfl-6004
