Help! Wheel keeps breaking off!
Old Dec 9, 2016 | 01:15 PM
  #21
dbbd1's Avatar
dbbd1
Okay, so in 4low, driveshaft removed, it stalls? Got to be that t-case retainer then. Just drop the rear shaft, 4 bolts to undo the tail housing. Check it out. It just takes some rtv to seal it back up.
Old Dec 9, 2016 | 01:19 PM
  #22
Zachwils95's Avatar
Zachwils95
I will check that out today. If that is the case, the t saver would do the trick?
Old Dec 9, 2016 | 01:21 PM
  #23
dbbd1's Avatar
dbbd1
Yeah, if it's not too far gone.
Old Dec 9, 2016 | 01:22 PM
  #24
dbbd1's Avatar
dbbd1
Of course, this still doesn't answer why you keep breaking off wheel studs...
  #25
Zachwils95's Avatar
Zachwils95
How could I tell if there was too much damage done? Like I said, it has snapped the wheel off 3 times, so it's taken a beating.
Old Dec 9, 2016 | 01:28 PM
  #26
Zachwils95's Avatar
Zachwils95
Perhaps the t case and CAD are both bad?
Old Dec 9, 2016 | 01:54 PM
  #27
2bit's Avatar
2bit
Is the RF wheel still locking up with the front driveshaft out? If it is, you need to take both sides apart and inspect it. If not, I think the tcase is the problem. Other guys tcases have grenaded because of the snap ring. I think your shaft moves and locks the front drive shaft while your driving. If that's what's happening, I would buy a different tcase and inspect the front axle and drive shaft very thoroughly. You could have twisted splines, chipped teeth, etc.
Old Dec 9, 2016 | 01:58 PM
  #28
Zachwils95's Avatar
Zachwils95
I have not given it the chance to lock up Since I removed the drive shaft. I havent had it above 10 mph.
Old Dec 9, 2016 | 02:04 PM
  #29
2bit's Avatar
2bit
I definitely think it's locking up the front shaft. For some reason yours locks up the RF wheel instead of grenading the tcase .
  #30
dbbd1's Avatar
dbbd1
Since you removed the front driveshaft, it still stalls but does it still break off the studs? If not, maybe the t-case shaft slides, locks into 4wd while driving it snaps off the studs and tire. Maybe the t-case saver is sell you need. I would try it first before swapping in a new t-case.
