Heat doesn't get very hot
What temp thermostat?
How did you remove the air from the system? Best way seems to be parking it pointing uphill on a rather steep incline. I even used ramps and a hill. You want the filler neck to be the highest point of the system. Let it run up to temp like that plus another 10-15 minutes, goosing the gas from time to time.
Did you drill a small hole in your new thermostat? This seems to help bleed some air out as well.
my 98 Durango (no longer own) and 99 2500 both used to read where the right side of the needle was going through the middle of the two before I changed the thermostats out in them (water pump jobs), and afterwards both read where yours is at now. I was stumped on this for a long time and decided the old stats must have just been running hotter from age or something. I still had about same cabin heat which wasn't great because I think the cores where due for changing.
changed out with same temp stats too
