trouble finding the right fuse.
Old Dec 19, 2016 | 08:42 AM
acain's Avatar
acain
Default trouble finding the right fuse.
Hello all. Merry Christmas.
My dash lights have gone out, and at the same time, my tail lights. Brake lights and turn sigs work fine. I cant seem to locate the fuse, on the side of the dash, or beneath the hood. Any one know wich one it would be? Im assuming a fuse is the culprit, anyway..
Old Dec 19, 2016 | 08:43 AM
What year is your truck? (should really put that info in your sig. )
Old Dec 19, 2016 | 11:43 AM
acain's Avatar
acain
Old Dec 19, 2016 | 12:11 PM
Fuse 13 in the one on the side of the dash.
If the fuse is good, have a close look at the headlight switch, and it's connector, they had a bad habit of melting on the 3/4 and 1 ton trucks.
You can grab a service manual for your truck from here.
Old Dec 20, 2016 | 09:43 AM
acain's Avatar
acain
Thanks. Yeh, couple years ago I remember the headlight switch kept heating up and partially melting. last night I changed out the five amp fuse in the cab. I changed out the switch for a new one, even though I inspected the old switch and the wiring and found no apparant damage. Still no dash lights and no tail lights. brake and turn lights are working. I let the truck run a few minutes with the switch on and felt the wires comming from the switch, they dont seem to be getting hot. I looked at the bulbs themself, they are ok. In the power distribution center under the hood there's also a 50 amp fuse for instrument panel/horn/parking lights. Im not sure if "parking lights" means tail lights, but at any rate, that fuse also looks good. The only other thing I see in the system is a small block thats attached to some of the wires comming from the switch, not sure what it is, but wondering if it has any thing to do with it.
Old Dec 20, 2016 | 09:49 AM
acain's Avatar
acain
well, having some trouble uploading photos...
Old Dec 20, 2016 | 10:47 AM
Looks like a relay..... How many terminals does it have, and how many wires going to it?
Also, check where the trailer harness hits the rear wiring harness, they are known to cause some issues......
Old Dec 20, 2016 | 01:46 PM
acain's Avatar
acain
it has four terminals and four wires. black and yellow, black and yellow, red and pink, and black.
Old Dec 20, 2016 | 02:47 PM
acain's Avatar
acain
update. sort of. I notice now that if I pull the headlight switch out slowly and carefully, and get it at just the right spot about three quarters of the way out, the tail lights do come on. kind of in between positions where parking lights and full on would be. Im thinking now that I may have bought a faulty switch?
Old Dec 20, 2016 | 03:34 PM
Sure sounds that way. Wouldn't be the first time I saw a bad part, right out of the box.
