my headlights are always on when the ignition is in the run position and the switch is off. I've just replaced the switch and it didn't fix the problem. Does anyone have any tips on where to start looking for wiring problems?
If the lights are on all the time, but, go off with the ignition, then you probably have daytime running lights...... If you are in Canada, that's a certainty.
