Roller rockers, "too compressed"
Mind you, English is my mechanic's 2nd language. He just installed a hughes airgap, and some 1.7 adjustable roller rockers. He said he couldn't get the truck to start with the roller rockers, and in his text read,
"The valves are very compressed".
I told him to ensure he soaked them in oil prior to (he did), and not to torque them over 20 ft/lbs. He said that is not the problem.
Any thoughts on what, "the valves are very compressed" could mean, and possible resolution?
I have the following in the moter:
Pushrods: Melling MPR-462
Mopar Performance Valve Springs DCC-5249464
Mopar Performance Valve springs retainers DCC-4452032
compcam 20-744-9
compcam 20-744-9
I'm wondering if something like the pushrods need to be changed. too long/ too short, etc.
I just went by his shop. He didnt know how to describe what a pushrod is. in english.
He told me the valves remain open, even when he adjusts them. (They are adjustable).
Is it possible I need shorter pushrods with adjustable rockers? And how I know how short to get?
Also, with shorter pushrods, is there still an advantage of the H.S. roller rockers over the stock?
Thanks.
Go here for a photo of what a pushrod looks like:
http://www.jegs.com/p/COMP-Cams/Comp...47156/10002/-1
The pushrods he has are 6.931 inches long. If he can't adjust the rockers to allow for the valves to open and close properly, he will need shorter pushrods. If the engine block was decked or the cylinder heads shaved (or both), this could likely have caused this issue. Might want to measure the length of those pushrods to ensure that the length is accurate. You possibly may have been given the wrong length pushrods in that box.
Thanks.
Thanks.
Trending Topics
...Any thoughts on what, "the valves are very compressed" could mean, and possible resolution?
compcam 20-744-9
compcam 20-744-9
Will those valve springs handle that much lift?
Do you need deeper pockets or beehive springs?
But....Springs and valves are only part of the equation. The reason for the lift limit is generally spring retainer to valve guide interference and coil bind, Magnum heads are limited because "truck motors".
I don't know what the limits of stock Magnum heads are, first mod I did was throw em in the trash.
Ha ha...I missed this.
Classic example of blind leading the blind....Sorry.
