Oil Pan for new build
Old Dec 28, 2016 | 07:48 PM
Thefiremon's Avatar
Thefiremon
Default Oil Pan for new build
So this is a quick and easy question.
I'm building a new motor and I am putting a high capacity oil pump and need a larger oil pan. Anyone have any suggestions. I have looked on google and found these pans in the list below.
http://www.milodon.com/oil-pans/off-...pans-chrys.asp
http://www.champpans.com/products/p/cp360-9rr/
http://www.kevkoracing.com/mopar.htm
Don't really know anything about any of them. Just want a good oil pan. Thanks
Old Dec 28, 2016 | 08:24 PM
Adobedude's Avatar
Adobedude
High "capacity" oil pump?
Volume or pressure?
I ran a stock oil pan on my 11 second Dakota for years, I still run a stock oil pump, you don't need a better oil pan.
Old Dec 28, 2016 | 08:52 PM
Moparite's Avatar
Moparite
Stock pans are fine unless your drag racing, Then you run a windage tray.
Old Dec 29, 2016 | 12:00 AM
AtomicDog's Avatar
AtomicDog
I'm running the Milodon pan on my truck and haven't had any issues at all with it. Its certainly more oil pan than I need right now, but I got it used a while back at a real good price and it included the braided dipstick tube. I also run a high volume oil pump along with an old school Direct Connection windage tray I had laying around.
Old Dec 29, 2016 | 12:30 PM
Thefiremon's Avatar
Thefiremon
Well to clarify, I am running a high volume oil pump. The reason is I took the expensive plunge into finishing a stroker motor that a friend had already started. So that being said I wanted the high volume pump to meet the extra needs of a high compression 408.
I am leaning towards the milodon unless anyone else has a suggestion
Old Dec 29, 2016 | 12:39 PM
AtomicDog's Avatar
AtomicDog
What vehicle is this motor going to end up being put in?
Old Dec 29, 2016 | 05:25 PM
I run a high volume pump, with the stock oil pan, no issues.
Old Dec 29, 2016 | 06:08 PM
Thefiremon's Avatar
Thefiremon
legitimate question. forgot to mention it. 2001 Dodge Ram 1500
Old Dec 29, 2016 | 08:16 PM
AtomicDog's Avatar
AtomicDog
Great. I assumed it was a truck since you posted the question here, but wanted to be sure, since truck pans are typically rear sump pans.
