I have been having a heck of a time burping my cooling system. I've been on hills, mountains, curbs, driveways, everything trying to get it right.
New
Thermostat (dealer)
T housing
Water pump
Hoses
Symptoms
When it warms up for 1st time, temp goes to 215ish then back to 180ish. On highways, stays consistent at 195-205. Stop and go traffic, runs at around 215.
Heat is good only during first 10 seconds heater is on, then back to cold.
I suspect air still in the system. I have come up with an idea of installing a T on one of the heater hoses, attaching a small peice of hose to that T, with an on/off valve at the end.
In my mind, I could bleed the air out, while also adding coolant that way.
I just want to poll this site before I do it and see what you all think. Do you think it will work?
New
Thermostat (dealer)
T housing
Water pump
Hoses
Symptoms
close
- Join DateApr 2010
- LocationClayton MI
Liked:4,223 Times in 3,915 Posts
That was something I seriously considered doing as well, to improve heater performance. I just haven't gotten to it yet....... I was just going to put a flush t in the heater return line, right by the heater core. (highest point....) Run the engine with the radiator cap off, and just crack the cap open, till air quit coming out.... It *should* work perfectly......
Quote:
Originally Posted by Zbss2233
Would it be better to put it on the return hose? The inlet hose seems easier to get to...
Quote:
I put one on each. (Maybe I simply have too much time on my hands)Originally Posted by HeyYou
You want to be able to force the air out of the heater core, so, return line is where it needs to be.......
Quote:
Right now I plan to do it on the return hose. Can you explain what you used? Originally Posted by dbbd1
A flush T?
A 3 way T with a on/off valve?
I just want to see what's easiest and best. Thanks.
Heater problems are all to common here.
