Identifying axle gearing
Old Jan 29, 2017 | 11:15 AM
j576's Avatar
j576
Default Identifying axle gearing
Need help identifying the gears in my front axle
The ring says L4 D44-411T 304 and then 079 on the opposite side to the first numbers
Old Jan 29, 2017 | 11:21 AM
dbbd1's Avatar
dbbd1
Should be a small metal tag, held on by one of the diff cover bolts, that has some numbers on it.
Old Jan 29, 2017 | 11:27 AM
j576's Avatar
j576
3.54 610631-1
That's what the tag says
Old Jan 29, 2017 | 11:34 AM
So stock was 3.54. But, by the numbers on the gears, looks like 4.11's......
If you have the driveshaft off, (four bolts... really easy) mark the ring gear, note it's position, then see how many times the pinion gear goes around for one revolution of the ring gear.
Old Jan 29, 2017 | 11:39 AM
j576's Avatar
j576
HeyYou haha was wondering if you were going to be the one to help me solve another problem, the trucks been great since we solved the misfire issue but getting it into 4 wheel drive isn't so great. When I lock it in and try and drive it feels like the front is working against the rear, which is why I pulled the cover and don't trust the tag, there's been a few weird things with this truck that the previous owner never told me about so trying to figure it out
Old Jan 29, 2017 | 11:56 AM
If you have different ratios front and rear, yeah, it just ain't gonna work well. It'll break things if ran that way. Verify ratios on both ends, see what ya got.
Old Jan 29, 2017 | 12:39 PM
j576's Avatar
j576
I know rear is 3.55 cause I just put it in like 6 months ago, going to confirm front today
Old Jan 29, 2017 | 01:12 PM
j576's Avatar
j576
Front is 4.11 gearing ! Wish I knew that before I re did the rear ! What's a better gearing 3.55 or 4.11 ?
Old Jan 29, 2017 | 02:00 PM
44dakota's Avatar
44dakota
4.11 without a doubt, you'll have more power, better fuel economy, and a longer lasting transmission as well...
Old Jan 29, 2017 | 04:38 PM
Sonocativo's Avatar
Sonocativo
Should be a decal on the underside of hood, next to the hook as you look up. It will give you a ton of info including axle gearings
