Engine swap. Will it fit?
Old Feb 4, 2017 | 07:50 AM
Hugues Mercier's Avatar
Hugues Mercier
Default Transmission swap. Will it fit?
1995 ram 2500 2wd 5.9l gas transmission is the same as 1996 ram 1500 2wd 5.2l ??
Old Feb 4, 2017 | 09:38 AM
No. They aren't, you need a trans from a 94 or 95.
Welcome to DF!
Old Feb 4, 2017 | 10:50 AM
Hugues Mercier
both are not 46rh?
Old Feb 4, 2017 | 11:08 AM
CJSuhr's Avatar
CJSuhr
94 and 95 1500 trucks are Obd1 and have Thebes's 46rh. The h stands for hydraulic control.
96 and newer 1500 trucks are obd2 (96 is first year of obd2), and they have the 46re. The e stands for electronic controll.
Old Feb 4, 2017 | 11:09 AM
Hugues Mercier
was made 11/95
Old Feb 4, 2017 | 11:10 AM
Hugues Mercier
and don't have 8 pins collector
Old Feb 4, 2017 | 11:52 AM
xjarhead69's Avatar
xjarhead69
this may answer your question https://dodgeforum.com/forum/2nd-gen...wap-guide.html
Dave
Old Feb 4, 2017 | 11:54 AM
xjarhead69's Avatar
xjarhead69
Also call dealer and get free build sheet for your truck, just need vin number.
Dave
Old Feb 4, 2017 | 12:16 PM
If it's a three pin for trans control, that is indeed an RH, and it will likely work. Seems not all 96's moved to the RE.
Old Feb 4, 2017 | 01:33 PM
Hugues Mercier
Thank u all
