Vacuum Leak Behind Dash
Old Feb 11, 2017 | 11:44 PM
  #21
CJSuhr's Avatar
CJSuhr
I have this hissing noise, sounds like a small leak, not sure how to explain the noise. It's very prevelant when cruising down the highway, with the radio off and windows up. Sounds like it's coming from behind the radio. It slowly dies off as I come to idle/stop. Can't hear I think at idle. No adverse effects and it doesn't drive me crazy so I'll, live with it.
Old Feb 12, 2017 | 08:20 AM
  #22
Chunx89's Avatar
Chunx89
Sounds like a firewall leak
Old Feb 12, 2017 | 10:23 AM
  #23
Chunx89's Avatar
Chunx89
Well that hose wasn't damaged at all so most likely the dash is gonna have to be pulled
Old Feb 12, 2017 | 12:17 PM
  #24
dbbd1's Avatar
dbbd1
Not sure if you want to try this, but...
You could cut each vacuum line running through the firewall, with the intention of splicing it back together, to isolate which line (if any) is leaking. Cut each, one at a time, plug it off, and go for a drive. Splice them back together with a piece of tubing slipped over each end, maybe with a touch of RTV sealant.
Old Feb 12, 2017 | 05:54 PM
  #25
Spillage's Avatar
Spillage
All I know is, the next time my dash comes out, I'll be drilling a hole through the firewall specifically for the vacuum line, with a rubber grommet installed... how it should have been from the factory... tucking it through the A/C line opening against a raw edge was brainless.
Old Feb 12, 2017 | 05:56 PM
  #26
Oh, but, they saved a whole nickel per truck by NOT drilling that hole......
Old Feb 12, 2017 | 06:17 PM
  #27
Chunx89's Avatar
Chunx89
Gotta love the way they make them, this is my first Dodge I've always been against them haha. Honestly so far any work on this thing has been a breeze I must say
  #28
Spillage's Avatar
Spillage
Yup they sure did... yet they have a hole w/grommet into the cowl for the reservoir, that could have been bolted to the firewall.
Old Feb 18, 2017 | 04:16 PM
  #29
Chunx89's Avatar
Chunx89
I had time to drop the dash, this is all I can see. I can't locate any vacuum hoses besides the green one. The noise is coming from where the picture is showing. I'm almost positive it's the line going into the firewall
Old Feb 19, 2017 | 10:31 AM
  #30
Chunx89's Avatar
Chunx89
I cut and re-routed my vacuum line going through the firewall and it still does it. I didn't bother with the green one because I figured the actuator is working so it must have vacuum going to it? I'm really stumped on this, as the noise is coming from glovebox area. I checked vacuum lines under cowl and they checked out ok. Which way are the check valves suppose to be facing? I'm stumped, it sounds like a vacuum leak to me, it only does it when you hit the gas and only when your in gear doing it. It's very loud, and I feel a power loss from a dead stop. Maybe I just have wild vents? And the noise is the wild vents kicking in, but when I hear this sucking noise as the Rpms raise then I hear the wild vents kicking on.
Also props to Beeker for the awesome write up about removing dash. I literally had it apart in under 30 minutes, no cracks!
