Torque converter problems? 46re
Old May 16, 2017 | 05:42 PM
  #41
Scottmed1's Avatar
Scottmed1
The truck is running great, shifts feel good, power is there but today I noticed a fast ticking noise coming from front of the transmission after the truck is warmed up. The noise is louder while in park or neutral but I can hear it in drive and reverse but barely at all and only when I hang out the door with my foot on the brake(ebrake cable is snapped) and listen closely . The noise doesn't seem to be causing any problems at the moment. Any thoughts?
Old May 16, 2017 | 07:45 PM
  #42
Just keep it in mind, and if it gets worse, go looking for it.
Old May 20, 2017 | 02:32 PM
  #43
Scottmed1's Avatar
Scottmed1
When my dodge was laid up I was driving the company dump truck, a 99 gmc 6.5 diesel 5spd manual. I never had a problem with it other than having to double clutch 3rd gear but The first day another guy drove it I think he killed the transmission. I got in yesterday and the clutch felt normal but 1st and 2nd weren't there , the shifter just felt like it was in neutral but 3,4,5 and r felt normal. Could there be a problem with the shifter or is it more likely the transmission is shot?
Old May 20, 2017 | 03:59 PM
  #44
More likely something internal to the trans.
Old May 20, 2017 | 07:25 PM
  #45
Scottmed1's Avatar
Scottmed1
That's what I figured, that thing has been pulling way more weight than it was meant to for a really long time. I took it easy when I was driving it but can't speak for everyone else . Guess we should be happy it lasted as long as it did
Old Jun 4, 2017 | 10:05 AM
  #46
Scottmed1's Avatar
Scottmed1
So the ram is running pretty good, the ticking noise seems to have sorted itself out somehow. I have noticed it seems a bit slow getting back down to first gear . When I have to stop at a stop sign or to turn left sometimes I have to wait a second or 2 and give it gas slowly for it to downshift back to 1st . If I just stop and try to take off right away it feels like it's still in a higher gear then it will downshift to first pretty hard before it takes off. Any thoughts? Could readjusting the bands help. I Already made sure the fluid was topped off properly
Old Jun 4, 2017 | 10:22 AM
  #47
Adjusting the bands sure won't hurt...... and that will also change some of the fluid, and the filter..... another plus.
