1995 dodge ram 2500 V8 5.9 steering play
Old Feb 16, 2017 | 02:02 PM
USMC@2018's Avatar
USMC@2018
Default 1995 dodge ram 2500 V8 5.9 steering play
Anyone know how to make the steering tighter so I dont have to turn the wheel 4 inches before it turns the wheels
Old Feb 16, 2017 | 02:09 PM
CJSuhr's Avatar
CJSuhr
Jack up the front end and put in on jack stands. Put your hands at 9 and 3 move the wheel. Look behind and see if there is any movement in the ball joints. Also, look for play on the pitman arm. Check the steering for any visual problems aswell.
Old Feb 16, 2017 | 02:23 PM
USMC@2018's Avatar
USMC@2018
Its been jacked up since I had to replace the tranny while I was under there I replaced literally everything I could think of its just the wheel play I mean when I Drive it it gets tighter but not a whole lot
Old Feb 16, 2017 | 02:35 PM
USMC@2018's Avatar
USMC@2018
Old Feb 16, 2017 | 05:52 PM
Welcome to DF! And thank you for your service.
If you have replaced everything else in front, it's probably the steering box. They are rather notorious for that kind of behavior. You could try adjusting it.... but, it's best to pull it out, and do BOTH adjustments if you are going that route. Or, you could replace it. The stock replacements you get at the local parts stores though, aren't always the best idea. You might get lucky, and get a good box, but, chances are, it will be just as bad, or worse.... than what you have now. If you want to go the replacement route, go with a redhead, or borgeson steering box. They are pricey, but, MUCH higher quality than the stock reman fellers.
Old Feb 17, 2017 | 02:56 PM
USMC@2018's Avatar
USMC@2018
I was really lucky went to autozone and Orielly's the guy at autozone said they'd have to order one but the guy at Oriellys said that they had a Borgeson steering box that the guy called in and said he didnt need it so I got i half price and put it in last night and damn its tighter than fort Knox. thanks for the info really helped out a lot
Old Feb 17, 2017 | 06:45 PM
Well you lucky SOB. It just doesn't get any better than that.
Old Feb 17, 2017 | 08:53 PM
'96 Power Wagon's Avatar
'96 Power Wagon
