Dodge ram 2nd gen 2500 V8 starts wobble at 70
Old Feb 22, 2017 | 12:17 PM
USMC@2018's Avatar
USMC@2018
Default Dodge ram 2nd gen 2500 V8 starts wobble at 70
I recently replace my transmission in a 1995 dodge ram 2500 v8 5.9l and it runs fine and everything but once I hit 65 it starts to wobble and when I get to 75 it sounds like it is hitting high rpms and just starts shaking the drive line I dont want to push it past 75 incase somethings is wrong with it any help will be much apreciated
Old Feb 22, 2017 | 12:18 PM
Moved to the correct section.
Old Feb 22, 2017 | 12:23 PM
USMC@2018's Avatar
USMC@2018
Thanks wasnt sure how to get to the 2nd gen forum
Old Feb 22, 2017 | 12:30 PM
You start here: https://dodgeforum.com/forum/
Scroll down to the Dodge Trucks section, click the "2nd gen Ram tech" link.
You've posted there numerous times already.
Old Feb 22, 2017 | 02:00 PM
USMC@2018's Avatar
USMC@2018
I posted once and that was because I googled it. Im just trying to get help on my pickup you dont need to be a a$$
Old Feb 22, 2017 | 02:22 PM
Not being an a$$. Stating a fact. Simmer down.
Old Feb 22, 2017 | 04:36 PM
Do you feel the shake thru the seat, or the steering wheel? What RPM is the engine turning at 65?
Old Feb 22, 2017 | 08:16 PM
AtomicDog's Avatar
AtomicDog
2WD or 4WD truck?
Old Feb 22, 2017 | 08:59 PM
denn69's Avatar
denn69
Does it have the 2 pc drive shaft in the rear? Those are know for vibration issues
Old Feb 25, 2017 | 12:29 PM
Ramman18's Avatar
Ramman18
When the driveshaft was removed, did you mark it so it went back on the same way? If not, might need to replace a ujoint.
And about the forum, it can be confusing with the layout since every forum in the world is unique. Google is the best search in the world and I even use it for searching this forum. If the only way he found us before was through Google, I can understand how he was in the wrong section. Happens all the time to the General topic forum. Keaton was a bit snooty in his response as if the OP should have known better. Let's all just agree to be helpful here no matter the situation!
