LMC headlight harness install
Old Mar 3, 2017 | 02:31 PM
CJSuhr's Avatar
CJSuhr
Default LMC headlight harness install
Quick diy using the LMC #55-9505. This kit is used for the single headlamp assemblies. It will be the same process somewhat for the dual, but that uses another extra harness.
This harness had both a relay for the high and low beams. It draws power from the switch to activate the relays, and then draws straight from the battery for the headlights. No more melted switches.
Materials needed:
- 1 LMC 55-9505
-2 16-22 awg male spade connectors
-2 Female spade connectors(guage size depending on what gauge your fuse holders are)
-2 crimp loop connectors
-2 fuse holders
-2 20amp fuses(mine used the ato sizes)
-2 10-12 awg crimp and seal connectors
- Some 10 or 12 guage wire
- wire conduit
- zip ties
- 2 screws for mounting the relays
Tools:
-wire strippers
-dikes
-flathead screwdriver
-sockets and ratchets
1: Take your harness and disconnect the part that bolts to the battery. Cut off the ends and strip them, and then add the 2 16-22 awg male connectors. Next, strip the ends of your fuse holders, and add the loop connectors and your female spade connectors. The connect your battery harness to your spade connectors. We need to add the fuses as the LMC harness doesn't have them.
2: Now remove the fuses and put both the loop connectors on the post in the PDC that comes off of the alternator.
3: now lay out your larger harness, with the relays and 2 connectors on the driver side area, next to the headlight. Rout the longer skinnier portion of the harness over the top front of the fan shroud, and unplug the factory headlight harness, and plug in the new one. Rout your ground wire down to the ground point next to the little black box, just below the headlight.
4. Next I undid the driver headlight harness, and plugged in the factory connector to the female connector on the new harness, and then plugged in the headlight. I took a few inch length of some 10 guage wire I had lying around, and extended the ground wire so I could reach up to the fender, where the battery hounds to the fender.
5. Now I mounted the relays. I drilled 2 holes in the battery box, and screwed the relays in the side, upside down. I put them upside down because that's how the harness wanted to settle.
6. Now I ran the part of the harness that connects to the batter behind the battery, by the hood release cable, annd then around to the PDC. I put some conduit on come of the exposed wire. It comes out of the PDC and routs around the back in the picture, hard to tell.
7. Now I put some conduit on the harness that goes over the top of the fan shroud, and then drilled holes through the fan shroud on where there are spaces for zip ties through the top of the rad core.
8. Finish by putting zip ties, conduit and black tape where needed, and then plug the Small connector between the battery harness and headlight harness in, and put your two 20amp fuses in. *NOTE the factory system uses a 15 amp fuse for the headlights, I would not put in anything over 20 amp, UNLESS you are running a set of HIDs or LEDs or anything other than the factory halogens that require more power.
They work!
Old Mar 3, 2017 | 02:55 PM
madmikesmech's Avatar
madmikesmech
Nice Christian! The lights look bright, do you notice a great improvement in the illumination while driving at night on actual road conditions?
Old Mar 3, 2017 | 05:34 PM
CJSuhr's Avatar
CJSuhr
Well, I literally just installed it today. So I haven't gotten a chance to try them out at night lol. But I'm pumped for when I take it out in the morning for work.
Old Mar 3, 2017 | 05:46 PM
madmikesmech
Yeah that's great! I myself just ordered that same item from LMC! So now I will scrape up those other components you suggested and I'll be ready when it arrives. I ordered some new OEM like headlights from Speed Daddy on eBay the headlights just arrived today
http://http://www.ebay.com/itm/40107...%3AMEBIDX%3AIT
Great install log on how you did it and nice illustrations A+++
Old Mar 3, 2017 | 09:33 PM
Yeah, this is going to end up in the FAQ/DIY forum in the not real distant future. Just need to proof-read the first post, and off it goes. (probably tomorrow. )
Old Mar 4, 2017 | 09:00 AM
Moparite's Avatar
Moparite
You may want to check the part #'s also.
Materials needed:
- 1 LMC 55-5905
It's 55-9505!
http://www.lmctruck.com/icatalog/de/full.aspx?Page=53
Old Mar 4, 2017 | 09:33 AM
madmikesmech
Well I certainly hope that LMC part # is correct!! It's the same one I just ordered, LOL! Threads like these are what separates this forum from the other ones out there! Mopar brothers sharing knowledge and experiences!! And admins that care about the forum
Old Mar 5, 2017 | 10:11 PM
CJSuhr's Avatar
CJSuhr
Originally Posted by Moparite
Got it fixed, thanks for noticing. That could've been catastrophic
Old Mar 6, 2017 | 11:12 AM
Ramman18's Avatar
Ramman18
I wouldn't have room for any more wires with all my added relays and accessory lights, plus relays like to go kaput for no reason. But for you guys with old pull switches (94-98) its really a necessity. Good job.
Old Mar 6, 2017 | 01:18 PM
dbbd1's Avatar
dbbd1
I used a small, waterproof box (tackle box) for the relays and secured it to the top of my PDC. This helped keep my battery-to-headlights wires as short as possible too. But, I also made my own harness too.
Mine's a '99.
