Transmission problems.
Old Mar 6, 2017 | 12:56 PM
Sure can't hurt. The grease might be dielectric grease..... it's put in there to keep water out of the connections. You can get it at most any parts store. (and it's probably a good idea to have some in there.)
Old Mar 6, 2017 | 01:26 PM
dbbd1's Avatar
dbbd1
Originally Posted by Laurens Moja
So you guys think i'll have to get another connector maybe? Or what is the pigtail for? Convertor? And can anybody link to it? Looked on eBay partnumber 12445BK , can someone look if it's this? Can't copy link on my cellphone..
Is that the 8-pin connector? We might have the plug and a pigtail from a junkyard around here.
It's basically just silicone (just straight silicone) lube. A plain silicone o-ring lube will work just dandy.
Old Mar 6, 2017 | 05:27 PM
Laurens Moja's Avatar
Laurens Moja
OK, update : after work i've cleaned the connectors, didn't do them all.. just the big one..
Drove it for a while, seems like it shifts somewhat normal for now, BUT still don't have 4th gear I believe, higher rpm than the previous tranny...
75mph at 3000-3500 rpm... that's not how it should be right ? The previous tranny was like 85mph at 2500 rpm..
i'll look tomorrow how many pins the connector was, and clean the others aswell.
btw not suré if I said, but didn't renew the filter, or took off the pan... normally it's in good shape, done it a year or so ago, no miles on it , car stood still since! But I have the gasket & filter for it , so i'll do it coming days..
do you think I can cause some damage driving it? Only to work, say 10-15 miles max a day?
seems to "work good" I mean doesn't stutter or shake or noises ....
Thanks alot guys
Old Mar 6, 2017 | 06:30 PM
What year is your truck, and what year was the donor truck?
Old Mar 6, 2017 | 06:40 PM
Laurens Moja
The donor truck is a Dodge Ram 2500 longbed 5.9L from 97
It got put into a ram 1500 shortbed 5.2L from 2001
Old Mar 6, 2017 | 07:22 PM
And there is the problem. The electronics changed in 2000. You need to swap over the governor pressure sensor, solenoid, and retainer. Should solve your problems.
Old Mar 6, 2017 | 07:32 PM
dbbd1's Avatar
dbbd1
Done by just by taking off bottom pan, easy to get at then.
Old Mar 6, 2017 | 08:10 PM
I suspect you will also have to change the internal trans harness, I *think* the connectors are different. (but, not 100% on that....)
Old Mar 7, 2017 | 06:03 AM
Laurens Moja
So this morning i took it to the trannyshop. On the Road to it, it took 4th gear! The owner of the shop took it for a ride, said it drives well.. don't know how this can solve itself, maybe something on that connection, didn't touch it anymore since i've cleaned it..
In the trannyshop they gave me a price around 1800€ for a rebuild of the tranny, Will be with fortified Kevlar plates... Any opinions? Any good mods out there for the tranny?
Old Mar 7, 2017 | 08:19 AM
You don't need a rebuild, you need the correct electronics in the trans first.
