1994 ram 318 to 84 dakota wiring
Old Mar 13, 2017 | 11:08 PM
thapioneer's Avatar
thapioneer
Default 1994 ram 318 to 84 dakota wiring
i am needing to know what wires need power and what wires need ground to make the 1994 motor run, whole harness and engine and computer are from a 1994 ram 1500 318, the truck is a 1984 Dakota but got those wires taken care of. theres gotta be someone that has the colors wrote down from doing same kind of swap
Old Mar 13, 2017 | 11:17 PM
thapioneer's Avatar
thapioneer
gotta be someone on here that has used the obd1 computer an setup from a 1994 magnum. the 84 dakota side is simple as a 84 chevy but all data sux for describing what gets power or ground or what its sending out as power or ground
Old Mar 13, 2017 | 11:25 PM
thapioneer's Avatar
thapioneer
just say you wanted to power the motor for a dyno, what wires would get power or ground to make the motor run, everything is plugged in except tranny stuff and the 3 connectors that would have gone from computer to the bodyside of the 94 ram
Old Mar 13, 2017 | 11:30 PM
thapioneer's Avatar
thapioneer
anyone wiiiffffaaa iq on hhhhheeerrrrreeee
Old Mar 13, 2017 | 11:37 PM
thapioneer's Avatar
thapioneer
just needing a straight forward answer that works without the run around
Old Mar 14, 2017 | 01:43 AM
dbbd1's Avatar
dbbd1
Not like you're giving a lot of time between your snarky posts for a response...
Old Mar 14, 2017 | 08:11 AM
Download the Ram Service manual from here. Wiring diagrams are in section 8W. Will tell you everything you need to know.
Old Mar 14, 2017 | 12:24 PM
thapioneer's Avatar
thapioneer
snarky post huh, when i get a cave man answer like the one from heyyou, duh you might check here no i asked if anyone knows for sure what wires needed powered or grounded to make the motor run you people are as bad as the same idiots on google that when looking up swap projects you get the same stupid answers like all you gotta do is power it up......ok genius what wires what colors which end of the harness
Old Mar 14, 2017 | 03:59 PM
dbbd1's Avatar
dbbd1
Originally Posted by thapioneer
you people are as bad as the same idiots on google......ok genius what wires what colors which end of the harness
Contradicting yourself or is that more of your wit?
If you don't like the people and answers you get here, feel free to try somewhere else. Yahoo, Duck Duck Go, a library...
I would say that you set the tone of the responses to your question in your first five posts.
Old Mar 14, 2017 | 07:11 PM
Cave man answer?
Terribly sorry. It isn't my job to spoon feed you. Download the manual, figure it out for yourself.
