Truck died. Won't start
Old Apr 30, 2017 | 09:22 PM
iowaman0322's Avatar
iowaman0322
Default Truck died. Won't start
The other weekend it dies then I got it started again then died again. While that it make some clunking noises. The fuel pump sounds like it turns on. I checked spark and only get it from ignition coil wire. I removed the distributor cap and rotor. It looks like the rotor is bent and the cap has some gouges by the inside terminals. The distributor does turn but won't turn. Would this be a bad distributor.
1998 Dodge ram 1500 360
Old May 1, 2017 | 01:35 AM
AtomicDog's Avatar
AtomicDog
Sounds like the distributor, cap and rotor are shot and needs to be replaced. When removing it, be sure to mark it well, so that it goes back in the same position as it was when removed.
Old May 16, 2017 | 07:42 PM
iowaman0322
How do I get the stupid thing out. I don't see any nuts.
Old May 16, 2017 | 07:43 PM
Two screws, almost impossible to see with all the stuff they put back there. One on each side of the cap. If you feel around, you can find the 'ears' they go thru.
Old May 16, 2017 | 08:03 PM
iowaman0322
I got the ones on the cap. What about the distributor itself.
Old May 16, 2017 | 08:28 PM
Leave the distributor in place. Don't even move it.
Old May 18, 2017 | 06:36 AM
iowaman0322
It needs replaced
Old May 18, 2017 | 09:05 AM
Why??
Old May 18, 2017 | 09:06 AM
AtomicDog's Avatar
AtomicDog
If you feel that the distributor is bad (and it likely is shot, if the rotor is tearing up things inside the cap), be sure to mark the location of the distributor at the base and also the location of the rotor, so that the new distributor can be installed in the EXACT same location and orientation as the old distributor. If you don't do this, the truck will not start-up and require the fuel sync to be reset.
Old May 21, 2017 | 06:39 PM
iowaman0322
How do I remove the distributor?
