01 ram clutch assembly
Old May 20, 2017 | 04:44 PM
David Clauder's Avatar
David Clauder
Default 01 ram clutch assembly
I busted a hole in the clutch fluid line. Its a manual transmission....anyone know where i can get just the line? Ill i can find r the assemblys. If not does anyone know a good way to rig it up for awhile so i can get it back on the road.
Old May 20, 2017 | 05:01 PM
You can't get just the line. It's replaced as an assembly.
Old May 20, 2017 | 05:02 PM
David Clauder
Is there a way to patch it short term?
Old May 20, 2017 | 05:07 PM
If it's metal, you could get some line the right size, a couple unions, and cobble it together. Need a flaring tool for that exercise. Do NOT use compression fittings. They can't deal with the pressure.
If it's a soft line that blew up, nothing you can do with it. If you are REALLY lucky, you *might* be able to take the line off, bring it to someplace like TSC, and they might be able to make one up for you.
Old May 20, 2017 | 05:08 PM
David Clauder
Its a preformed line
Old May 20, 2017 | 05:34 PM
Then you should be able to patch it, if you have the right tools.
Old May 20, 2017 | 05:36 PM
David Clauder
What do i need
Old May 20, 2017 | 07:51 PM
The right size lines, two unions, 4 flare nuts that are the right size, and threads, and the flaring tool. Cut out the part of the line thats bad, slide the flare nuts onto the line, flare the line, screw the union on. Gotta do that for all four ends.
Old May 20, 2017 | 07:54 PM
David Clauder
It sounds like it would be easier to just replace the assembly
Old May 20, 2017 | 08:55 PM
Depends on where the line is routed. If you have to cut it in places that are difficult to get to, simply because that's where the 'good' line is.... yeah.
