1997 dodge ram 2wd 3inch lift
Old May 28, 2017 | 05:38 PM
Jacob Peterson's Avatar
Jacob Peterson
Default 1997 dodge ram 2wd 3inch lift
I have a 1997 dodge ram 2500 2wd i just installed 2.5inch blockes and 3" spring spacers the passenger side went on fine but the driver side the lower control arm doesnt seem to be seating properly as the stud on the upper ball joint it hitting the bump stop bracket what could be my issue
Old May 28, 2017 | 05:41 PM
Were the lift blocks for a 4x4 truck?
Old May 28, 2017 | 06:01 PM
Jacob Peterson
No i ordered it as a kit for my 2wd
Old May 28, 2017 | 06:02 PM
can you post a pic?
Old May 28, 2017 | 07:17 PM
Jacob Peterson
Of the kit or truck
Old May 28, 2017 | 07:30 PM
Jacob Peterson
After
Before
2.5 rear blocks and 3"front coil spacers
Old May 28, 2017 | 07:31 PM
Jacob Peterson
But i think i needed extended ball joints and longer shocks
Old May 28, 2017 | 08:09 PM
Jacob Peterson
So just took it for a drive and when i hit a bump there is a knocking noise and it bounces like a mf could it be bouncing because my shocks are basically extended all the way
Old May 28, 2017 | 08:53 PM
Did you remember to bolt them back in? (I've done that before.......) You may be bouncing against the bump stops...... or maybe one of your spring isolators got moved out of position, or just fell off.... Can you bounce it in the driveway, and make it knock?
Pic of where you are running into interference.
Old May 28, 2017 | 10:12 PM
Jacob Peterson
Well everything is bolted together but my shocks in front and rear are def extended all the way out
the bolt for my upper control are is knocking against the top of my bump stop causeing the knocking noise can i eather cut the off or is there a way to move the balljoint up The castle nut is the upper balljoint
