Cruise Control
Old Jun 4, 2017 | 10:54 PM
nervjiggy's Avatar
nervjiggy
Default Cruise Control
2001 ram 1500
CC will turn on and set but it will only set for a second and then stop pulling. Vacuum lines and reservoir appear to hold a vacuum.
What should be my next move?
Thanks.
Old Jun 4, 2017 | 11:58 PM
dbbd1's Avatar
dbbd1
Check your brake light switch on the pedal, trust me.
Old Jun 5, 2017 | 11:53 AM
nervjiggy's Avatar
nervjiggy
I can certainly replace the switch. I pulled the servo out and hooked up a vacuum pump then actuated the valves to let the vacuum in. My question is does the diaphragm hold a vacuum? It appears to be pulling in outside air. If it relies on a lot flow from the reservoir to compress the spring then that might explain why the vacuum pump doesn't cut it.
Old Jun 5, 2017 | 12:04 PM
dbbd1's Avatar
dbbd1
Yes, it should hold a vacuum.
Sorry for jumping to the brake switch...
Old Jun 5, 2017 | 12:52 PM
nervjiggy's Avatar
nervjiggy
No problem. Checking the servo was just a shot in the dark. I don't think any of the stores around here carry one so I may have to order to see if I'm right.
Old Jun 5, 2017 | 02:54 PM
nervjiggy's Avatar
nervjiggy
It would appear I did have a leak. Will update thread when the new servo arrives as I hate threads with no conclusion. Thanks.
Old Jun 9, 2017 | 07:33 PM
nervjiggy's Avatar
nervjiggy
I got the part put in today. Doesn't seem to set at speeds under 50. Perhaps I didn't keep a steady speed or a speed sensor? However it works at highway speeds which is all I wanted.
Old Jun 9, 2017 | 07:36 PM
dbbd1's Avatar
dbbd1
There is some kind of calibration to do, it's in the service manual.
Old Jun 9, 2017 | 07:37 PM
dbbd1's Avatar
dbbd1
And, is your speedo accurate? Most cars will not set usually below 35-40.
Old Jun 10, 2017 | 07:20 AM
Tboned's Avatar
Tboned
Thanks for update!
