Water pump/fan thread issue
Old Jun 10, 2017 | 06:52 PM
atc250r's Avatar
atc250r
Default Water pump/fan thread issue
So 7 years ago I was working out of town and needed my water pump replaced. An independent shop there replaced it for me. Today I changed that pump, and as I unthreaded the fan, I noticed the threads had been cross threaded. I got it off without too much difficulty. Now I go to put the fan onto the new pump, it will not thread on. Like an idiot, I forced it a bit and now both sets of threads (male and female) are both totally buggered up. I have the fan off right now, but the threads are a mess inside the big nut, as well as on my new pump.
I am a welder by occupation, so I'm considering filing/grinding down the male thread so that the fan slips onto the pump, then tack welding it on. But the next time I need to remove the fan I'd need to file or hacksaw the weld to get it off. Bad idea?
Any other ideas?
Oh, and on this pump the pulley is pressed onto the pump. The parts shop also had a pump with the pulley bolted on, but of course my old one wasn't like that.
Old Jun 10, 2017 | 07:03 PM
Get a new pump, go to the junkyard, get another fan. Save yourself some headaches later.
Old Jun 11, 2017 | 09:07 AM
Ramman18's Avatar
Ramman18
Grab a new fan clutch which is what the blades attach to and has the new nut. They can get old and not work over time anyway. I think mine was like $40 bucks and built in 'merica. Replace blades to the new clutch and don't be so superman next time!
Old Jun 11, 2017 | 09:08 PM
atc250r's Avatar
atc250r
What brand clutch should I ask for at the parts store?
Old Jun 11, 2017 | 09:16 PM
Whatever they have on the shelf. Doesn't really matter.
Old Jun 12, 2017 | 01:36 PM
Ramman18's Avatar
Ramman18
I don't remember. Let me look it up.....
Murray! From O'Reilly's stores. Made in USA!
But I was wrong, it's $60 bucks. Oh, well.
Old Jun 12, 2017 | 10:37 PM
atc250r's Avatar
atc250r
Done. New fan clutch and another new water pump tonight. All is good...I think
Thanks guys
Old Jun 12, 2017 | 10:40 PM
primem's Avatar
primem
delete
