Just cranks
Old Jun 15, 2017 | 11:20 AM
l481273's Avatar
l481273
Default Just cranks
1996 2500 dodge ram 360. Got wrapped off manifold. So after investgation one spark cut in half. So I had the bright idea to tune it up cap,rotor and such. Well in the process snapped rotor cap screws. Got #1 tdc and marked distributor and replaced with new one. Now she just cranks and cranks. Rotor is facing #1 cylinder and distributor. in same spot. I check only one wire and has spark. Had to stop down pouring. What could it be? Any help appreciated.
Old Jun 15, 2017 | 11:48 AM
I don't understand a thing you just posted.
Old Jun 15, 2017 | 01:39 PM
l481273's Avatar
l481273
Default Distributor replacement on 96 dodge 2500
I replaced the distributor with all new parts. Now the engine keeps cranking (it won't start). I checked the spark plugs and I do have spark. Did I explain it any better.
Old Jun 15, 2017 | 03:34 PM
Did you plug the cam position sensor back in?
Old Jun 16, 2017 | 04:44 AM
l481273's Avatar
l481273
Default Can sensor
Yes I did plug it back in
Old Jun 16, 2017 | 06:18 AM
Moparite's Avatar
Moparite
The dizzy position should be like this.
Old Jun 16, 2017 | 06:20 AM
l481273's Avatar
l481273
Yes installed as picture is shown.
Old Jun 16, 2017 | 09:01 AM
Need to check and see if you are getting injector pulse. Should be able to beg/borrow/rent/buy a noid light from the local parts store.
Old Jun 16, 2017 | 03:47 PM
l481273's Avatar
l481273
Ok thanks will check that out. Thanks a bunch.
