How To Video to Fix HVAC Wild Vent / Blend + Mode Door / Fan Speed
Old 06-16-2017, 11:10 PM
snoozeworm's Avatar
snoozeworm
snoozeworm is offline
Default How To Video to Fix HVAC Wild Vent / Blend + Mode Door / Fan Speed
Here's a video I created tonight after getting the last "bug" out of my hvac system on my old dodge. Hope it helps you guys out!
The following 3 users liked this post by snoozeworm:
David Payton (11-24-2021), Duke98 (11-17-2019), Mikem44 (10-26-2021)
Old 06-22-2017, 12:08 PM
Adobedude's Avatar
Adobedude
Adobedude is offline
Just what I was looking for....
Old 06-22-2017, 01:47 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
Made a sticky for you guys to find easier.
Old 09-09-2017, 07:37 AM
Moparite's Avatar
Moparite
Moparite is offline
I just wanted to add a few things, The earlier rams didn't have the blend door motor they where cable operated. A common fix for the one with the motor is the heater treater.
https://heatertreater.net/
Another issue is bad check valves, There is one on the passenger side port on the kegger and there is another up by the firewall. You can get replacements from napa for around $6. They are identical but you need to make sure of the vac flow direction before you put them on.
https://www.napaonline.com/en/p/NDP7301349
For people with the earlier rams there was a TSB on adding a check valve that you can read about.
http://dodgeram.info/tsb/1996/24-01-96a.htm
Old 10-26-2017, 09:29 PM
Larry Strickland's Avatar
Larry Strickland
Larry Strickland is offline
https://youtu.be/rQibAZa01ww
so where exactly is blend door located in the box.
Old 10-28-2017, 09:36 AM
Danlb0y's Avatar
Danlb0y
Danlb0y is offline
Love that fix! At least your model of dodge allows reasonable access to the system. 1998 durango is a completely different story. It seems like every thing to do with the AC system requires dash removal to rectify. Even the fan motor resistor pack requires a dash removal.
Old 10-28-2017, 04:48 PM
Danlb0y's Avatar
Danlb0y
Danlb0y is offline
I bought my D second hand with 15000 miles on it. The diagram you provided was great but it appears someone had already done the fix on mine before I bough it. I wonder if they just woefully under-designed that reservoir?
Old 10-28-2017, 05:06 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,179 Likes on 2,932 Posts
Some folks have added another reservoir as well....
Old 10-28-2017, 05:20 PM
Danlb0y's Avatar
Danlb0y
Danlb0y is offline
I should have tried adding another reservoir first. I ended up buying a new 12 volt vacuum pump and a adjustable vacuum switch. I haven't installed it yet. I may still add the reservoir before I do the pump thing. Who knows, maybe both would work in an over-kill sort of way!
Old 05-07-2018, 12:21 PM
mattross257's Avatar
mattross257
mattross257 is offline
I have had this issue where it would not change modes at all. We noticed a sucking sound coming from the dash. Further digging found the mode selector switch is vacuum operated and the ports that are on the back were cracked. We were able to find an old used one that worked just fine. Currently tho, many years later, it seems to have a mind of its own. In cruise control pulling a hill most of the time you will hear and feel the mode switch as if it lost the suction then return when you have crested the hill. And some days it won't change modes at all.
Quick Reply: How To Video to Fix HVAC Wild Vent / Blend + Mode Door / Fan Speed
