Transmission woes (No OD)
Old Jun 22, 2017 | 09:28 AM
MedicNathan's Avatar
MedicNathan
No luck with a data logger. I did cycle 12 quarts through the system. It is now nice and red.
Also had a new development. Overdrive did engage this morning, once. Engine temp was only about 140* at the time. Once I got on the interstate and the engine was up to temperature it wouldn't reengage.
Old Jun 22, 2017 | 09:41 AM
Did you get the check valve taken care of?
Old Jun 22, 2017 | 10:19 AM
MedicNathan
Check valve is still on the to do list. It shouldn't stop the OD from engaging at temperature though would it?
Old Jun 22, 2017 | 12:14 PM
Yes, if it is plugged up, the trans overheats fairly quickly, and the PCM will disable O/D. It *should* turn on the trans temp light in the dash though..... Does that bulb test when you first start the truck?
Old Jun 22, 2017 | 03:37 PM
MedicNathan
​​​​​​I wasn't aware I had a trans temp light on the 97.
I drained the fluid using the upper radiator port. Seemed like pretty powerful flow through there
Old Jun 22, 2017 | 04:30 PM
Ok, that's where it comes out.... So, you have flow at least.
Any codes yet?
Old Jun 22, 2017 | 04:32 PM
MedicNathan
Still no codes. I will get a 5 second bump by 250 rpm when I cycle the OD switch now
Old Jun 22, 2017 | 04:43 PM
That's TCC.
What RPM are you turning at 60 Mph? What gears/tire size?
Old Jun 22, 2017 | 06:13 PM
MedicNathan
2500 rpm I believe. And 31s with 3.55
Old Jun 22, 2017 | 06:19 PM
Yep, No O/D....
Hhhmmmm.... one would think the PCM would whine about that. Can you see what temp the PCM thinks the trans is?
