96 5.2 lack of power
Old Jun 24, 2017 | 10:02 PM
Robert Thomson's Avatar
Robert Thomson
Default 96 5.2 lack of power
Hey guys. First time posting. I have a 96 ram 1500 regular cab short bed 4wd. 5.2l auto. The truck had approx 140k on it. Trans rebuilt about 30k ago. I have a lack of power when I am towing anything. It's terrible trying to pull our 4k pound camper. Even rough with an empty car hauler. I have done the plenium fix, timing chain, water pump, rad, external trans cooler, 180 degree thermostat, plugs, wires, cap and rotor. I am running 33s with 456 gears. Any thoughts on why I am lacking power? It struggles to do 45 going uphill with the empty car trailer and wants to overheat as well.
Old Jun 24, 2017 | 10:11 PM
dbbd1's Avatar
dbbd1
How long ago was the plenum done?
First thing I'd do is unplug and remove the O2 sensor before the cat. Take it for a drive. It will throw a code. Let us know how it feels.
Old Jun 24, 2017 | 10:15 PM
Robert Thomson
I did the plenium less then 2 months ago with the aluminum plate from Hughes. I think that is the name of the place
Old Jun 24, 2017 | 11:06 PM
Not towing in O/D are you?
How's that cat? Is it clogging up? That would seriously compromise power.
Old Jun 25, 2017 | 07:28 AM
Robert Thomson
O/D off and had the cat checked last week. Had been changed at one time already. Exhaust guy said a few years had some issues rattling. Cat was not clogged. New o2 sensors too. Only code I have is high battery temp or something like that
Old Jun 25, 2017 | 09:03 AM
Time for a compression test.
Old Jun 25, 2017 | 08:59 PM
Robert Thomson
I did a compression test this afternoon. All cylinders look good. Anywhere from 145 to 165 on all 8. Not too bad for 140k. I also went ahead and changed out the champion plugs I had installed approx 4k miles ago. Replaced them with NGK V powers. Good thing I did. Stupid me failed to double check the gap on the Champions and they ranged from .020 to .030. I put the NGKs at .035. Made a big difference in idle and smoothness of running down the road.
Old Jun 25, 2017 | 10:39 PM
I never did like champion plugs.
