Flowmaster Delta Flow 40 Series
#21
Also, is there a difference in sound with a dual rear exit system as opposed to a single rear exit system? Zeekxxx, correct me if I'm wrong, but you have a single side exit exhaust system right? Your clip sounds really good, but does having two exits necessarily mean it will be louder?
#22
#23
ORIGINAL: vondoom
it should bring you to around 15 mpg...Its a quite a bit louder on the inside and out...Not obnoxious though, its got a sweet hum....i was getting 9-11 MPG, i got my magnaflow put on, now im at 15..Not sure how it will work on yours though...I have a 3" single pipe, 98 ram 4x4 5.9.....
#24
ORIGINAL: Off_Road_Teacher
Is that the system from the guy in N.C.? That is the one I got and it worked great. It came with everything he said and it fit up nice. I think the whole install only took an hour or so. Very nice kit and can't beat the price.
#25
I did it myself. It was pretty easy to do too. All of the parts that I needed came in the kit and the bends in the pipes fit the truck nice. I was kind of worried that buying a kit off ebay wouldend up with problems getting the pipes to fit, but they fit really well. It came with all of the clamps that I needed to install it but I decided to weld it just to be safe. Plus, since the tips have to be welded, I figured I might as well do the whole system.
#26
ORIGINAL: ripto
Would assume so. The side that my exhaust sounds like is like a megaphone. Whichever side it points at is the loudest. It is a single side exit not dual. Pretty much the stock system with the muffler cut out.. check out these pictures on this link
http://www.ronbarthelt.com/Ram4.html
#28
Well guys I finally had it installed and it took me long enough to make the post. I had it done on Christmas eve at the local meineke shop, took a little over an hour to install. I couldn't believe how awesome it sounded when I first started the truck up. I love how it sounds on the inside too, I want someone to drive my truck down the road in front of me just so I can actually hear it lol, it's hard to hear how it sounds when your driving it, although you can hear some on the inside. I wish it was a bit louder tho, I was thinking maybe I should have gone with the regular 40 instead of the delta flow 40 but I hear its a bit much from the inside. Oh well, I'm happy with it and my friends love it (mom hates it but that makes it all the better
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
#29
