Ghost problem now starting prob
Old Jun 28, 2017 | 09:07 PM
Check fuses in the PDC. Check connections there as well.
Old Jun 28, 2017 | 09:15 PM
Jerrit's Avatar
Jerrit
Have power to all the only thang that makes a sound is the the click to the asd
Old Jun 28, 2017 | 09:21 PM
Do the gauges test when you turn the key to start?
Old Jun 28, 2017 | 09:45 PM
Jerrit's Avatar
Jerrit
No gauges like the key is off but will crank no head lights nothing in cab
Old Jun 28, 2017 | 10:44 PM
Jerrit's Avatar
Jerrit
Nada all in cab is dead I have no clue
Old Jun 28, 2017 | 11:07 PM
Jerrit's Avatar
Jerrit
The pcm or ecm wouldn't just go out like that? Or could it? how could I test to know I'm at a loss .. on the pass side there is a double wire to the ground on battery that when you connect to bat the asd relay clicks with key off or on... tried it on a 2000 dodge and it don't click like mine if I pull a fuse don't remember which one the relay buzzes .. some one said chk the bcm isn't that the same as pcm
Old Jun 29, 2017 | 07:36 AM
Jerrit's Avatar
Jerrit
I'm going to try and disconnect both batteries and leave till lunch time and reconnect just a shot in the dark bc when I changed my terminals did it in about 10 mins don't know if there is like a fail safe or something like that I have tried doing a search for my problem and a idea and nothing that adds up only thing that made any since was to rest pcm/rem was disconnect batteries for 30 mins at least to disschange any power .. check ground to side of pcm chk a pin dont know what number to see if pcm has power
Old Jun 29, 2017 | 10:10 AM
Possibly the PCM, maybe the ignition switch. Going to have to check and see where you do, and do not, have power with the key on.
Old Jun 29, 2017 | 10:36 AM
Jerrit's Avatar
Jerrit
Was reading that may have with the arc of power may have trip the safety or fail safe in ecm or pcm to trigger the asd to open just trying to find that ( here I am problem)
Old Jun 29, 2017 | 11:00 AM
PCM will engage the ASD relay for three seconds when you first turn the ignition on. After that, it has to see the engine turning (crank, or cam sensor) to re-engage it.
