97 dodge 1500 5.9. wont start
97 dodge ram 1500 4x4 360 .
can't get it to start. I've replaced the pick up coil the cap and rotar and the crank shaft positioning sensor and it gets spark to all the plugs. I thought maybe the fuel system had an issue but pulled the line off the fuel rail and turned the key and gas shot out. And even poured gas down the throttle body. Am I missing something or shouldn't this thing light off. Maybe anti theft is making it not start? Idk any suggestions would help out a ton
I've done it probably 100 time and every once in a while ill get a diesel shaking for a split second. But usually after I let go off the key?
Any codes? Did you make sure you put the wires on correctly? It should run if you have gas and spark. Truck history? Did you just pick this up or was it running before?
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Trending Topics
