ABS not working
Old Jul 8, 2017 | 12:51 PM
Johnnybgoood1's Avatar
Johnnybgoood1
Default ABS not working
Ok , on my free truck, I was driving along and had to hit the brakes a little hard and the back wheels locked up and smoked the tires, I looked and saw the ABS light on the dash, is this a fuse or something deeper?
Old Jul 8, 2017 | 04:09 PM
2 or 4 wheel ABS?
The rear abs (2 wheel) doesn't work very well......
Old Jul 8, 2017 | 04:54 PM
Johnnybgoood1
Its a 4 wheel drive truck, how would I know if it is 4 wheel ABS ? where do I check?
Old Jul 8, 2017 | 06:42 PM
Check and see if there are wires for the front wheel speed sensors. If there aren't any wires, then you just have RWAL.
Old Jul 9, 2017 | 10:37 AM
Johnnybgoood1
No wires going to the front wheels, and I dont see any going to the rear, is there a junction box somewhere that is causing the wheels to lock up?
Old Jul 9, 2017 | 11:24 AM
May not hurt to inspect the rear brakes.
Old Jul 9, 2017 | 02:48 PM
Johnnybgoood1
took off the brakes and the pads look great, now the e brake doesnt work but I think the cable is stretched or broken, I will check that out, but still doesnt fix the ABS light on the dash lit up and the rear brakes locking up
Old Jul 9, 2017 | 03:56 PM
Check the sensor on top of the diff. They tend to fail. About all you can do is replace it.
Your speedo works properly, does it not?
Also: What year is your truck?
Old Jul 9, 2017 | 05:51 PM
Johnnybgoood1
Speedo works fine, its a 1997 1500 extracab 5.9 gas engine
Old Jul 9, 2017 | 07:07 PM
Ok, might just replace that rear wheel speed sensor then, and it *may* solve your problems.
