3rd gen suspension into a 2nd gen?
Old Jul 13, 2017 | 10:53 PM
97ramrod1500's Avatar
97ramrod1500
Default 3rd gen suspension into a 2nd gen?
Just curious if the front and rear suspension from a 06 Ram 2500 diesel would swap into a 99 Ram 1500? Asking cause one of my friends has the complete front and rear suspension from his old truck. So he's going to toss it unless I want it. If I could swap out my worn out half ton suspension then I'm going to.
Old Jul 14, 2017 | 08:56 AM
Is the donor 2 or 4 wheel drive? If 4 wheel drive, is it solid axle front suspension?
Old Jul 14, 2017 | 08:20 PM
97ramrod1500
4wd and yes I'm almost positive it was solid front axle.
Old Jul 15, 2017 | 10:49 AM
Would have to look, and measure. I don't know how much the frames changed for the 3rd gen trucks.
Old Jun 15, 2025 | 04:50 PM
wdog4's Avatar
wdog4
Default Any luck?
i’m in a similar predicament, i want to buy a 3rd gen lift for my 2nd gen dodge and i hope it’s similar, did you have any luck? updates or pictures?
Thank you!
Old Jun 15, 2025 | 08:14 PM
Thank you!
Only the 2500 and 3500 third gens were solid axle in front. If you have a 2nd gen 4x4, there are still lift kits out there in the world for it.
Old Jun 15, 2025 | 08:18 PM
wdog4's Avatar
wdog4
Ahh okay, yeah i know that lol, i was just browsing marketplace and found a killer deal for a lift and was curious on how compatible the axle/suspension was for these 2 trucks. Thank you for the info!
Old Jun 16, 2025 | 07:03 PM
dodgetruck2's Avatar
dodgetruck2
the biggest initial hurdle will be 3rd gen 2500 + trucks used 3" wide leaf springs, 2nd gens are 2.5" so shackles need changed out right away
Old Jun 16, 2025 | 07:08 PM
I believe the 2nd gen 2500 and 3500 also had 3" springs. 1500's had 2.5".
Old Jun 16, 2025 | 10:22 PM
dodgetruck2
I guess I'm not sure about the revisit, initial post was regarding a 1500.
In general terms the springs better be free, there's many more options that would be direct addition/swap that you can buy, vs buying something that isn't even correct
