Axle seal help
Old Jul 18, 2017 | 10:15 PM
Sperrydan79's Avatar
Sperrydan79
Default Axle seal help
Hi guys.
I'm having trouble finding a front Right/pass side axle seal that will be 100% correct. I've looked at rockauto AutoZone Napa and mopar parts and there are 10,000 seals witch one is correct.
My info is
01 dodge ram 2500 5.9l v8 4x4 automatic. extended Cab
I haven't torn into the job yet because I'm using this truck to help with a remodel on my old house. And can't have it down just yet. I'm just trying to get all my parts together so I can knock it out fast when time allows.
Old Jul 18, 2017 | 10:20 PM
Front or rear axle?
Old Jul 18, 2017 | 10:25 PM
Sperrydan79
I believe I said front right/passenger
Old Jul 18, 2017 | 10:32 PM
Ooops, I saw the right/passenger, but, totally missed the "front".
Edit: Link removed, wrong part.
Old Jul 18, 2017 | 10:44 PM
97ramrod1500's Avatar
97ramrod1500
Keep in mind that the axle seals on Dana axles install from the inside of the housing, not the outside like the rear Chrysler 9.25 axle.
- To install the front left (driver side) you have to pull the axles and carrier out of the housing.
- to install the front right (pass. side) you only have to pull the right outer axle and vacuum disconnect unit. I believe it's the called the CAD. then you have to make or purchase a puller to pull the seal into place in the axle tube.
Not sure if you were aware of this or not? It really sounds a lot worse than it is depending on your mechanical abilities.
Old Jul 18, 2017 | 11:41 PM
Sperrydan79
Yeah I've done it once before on a 1500 years ago I'm sure I'll figure out a way to do it if not I found a tool that will do it
Old Jul 18, 2017 | 11:44 PM
Sperrydan79
Oh and yeah does it matter if it's a Dana 60 or Dana 44 cuz I'm not quite sure which one I have a missing id tag and I've been told that it could be either or
Old Jul 19, 2017 | 01:29 AM
AtomicDog's Avatar
AtomicDog
Yes, I believe the Dana 60 and Dana 44 use different seals. You will need to determine which differential you have.
Old Jul 19, 2017 | 09:11 AM
jlake4130's Avatar
jlake4130
Quad4x4.com will have the seal you need.
Old Jul 19, 2017 | 09:13 AM
As your truck is a 1500, you have the D44.
There should be numbers stamped into one of the axle tubes. You can decode your axle with that. (at Dana's site.)
