Getting spark but no fuel.. need help
Old Aug 2, 2017 | 01:46 PM
corbin5754's Avatar
corbin5754
Does the ASD send power to the coil, or injectors for a few seconds when you turn the key on?
It gets spark so I'm assuming the asd is sending power to coil.
I put a multi meter to the crank sensor to the middle wire,with key on and didn't get a reading also
Old Aug 2, 2017 | 02:33 PM
If you are getting spark, then the ASD relay is doing its job.
What happens if you put a jumper in place of the fuel pump relay?
Old Aug 2, 2017 | 03:55 PM
corbin5754's Avatar
corbin5754
I'm not sure what you mean or how to do that
Old Aug 2, 2017 | 06:14 PM
If you look on the bottom of the relay, the terminals are numbered. In the socket the relay plugs into, stick a short piece of wire into pin 30, and the other end into pin 87. The fuel pump should run.
Old Aug 3, 2017 | 12:57 AM
corbin5754's Avatar
corbin5754
I'll try that out thank you. If it doesn't work what is my next step
Old Aug 3, 2017 | 01:06 AM
corbin5754's Avatar
corbin5754
And I take it if the fuel pump does send fuel the relay is bad?
Old Aug 3, 2017 | 09:46 AM
If the pump runs with the jumper wire, then either the relay is bad, or the PCM does not want to engage it, for whatever reason...... Test and see if the pump runs, take it from there.
Old Aug 4, 2017 | 09:37 AM
corbin5754's Avatar
corbin5754
Can I try and start the truck using the jumper? I work night shift and will be doing this at 4am so won't have a helper listening for pump to prime.
Old Aug 4, 2017 | 09:55 AM
Sure can.
Old Aug 8, 2017 | 04:05 AM
corbin5754's Avatar
corbin5754
Tried the jumper wire still nothing
