Need help
Old Aug 4, 2017 | 07:44 PM
How often do you plan to go in there.
If you want to make your life easier, should you need to be in there again, get the rubber gasket, and a drain plug to install as well.
Old Aug 5, 2017 | 08:06 AM
Moparite's Avatar
Moparite
Don't ever use cork for anything, It will leak! Do you know what cork is? Is it tree bark, That's not a good sealer use the rubber gasket.
