New To the Forums
Old Aug 5, 2017 | 11:09 AM
  #21
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Not just off-hand..... I *think* he is in the Carolinas somewhere..... but, not 100% on that. I am pretty sure it is mentioned somewhere in his thread..... (yeah, somewhere in 80 some odd pages......)
Could always install a Mega Viper. I think they are rated to 800 or so.....
Hhhmmmmm....... I think something is amiss with your motor. Even synthetic oil should be that low..... I was thinkin' maybe you were using 0W20, or some such..... THAT might explain it....
I would be real tempted to yank the oil pump, and test it.......
Restriction in the oil passage to the sensor? Maybe?? (see that straw I am grasping at? )
Bed time for me. Got a family reunion we are hosting HERE (my place) tomorrow. Should be fun. I'll be glad when it's over.
I'm going to yank the oil pump and test it to see if that is the culprit. If not time to tear it down lol
Old Aug 5, 2017 | 11:16 AM
  #22
We havin' fun yet?
Old Aug 5, 2017 | 04:51 PM
  #23
MoparFanatic21
We havin' fun yet?
I don't mind tearing it down. The oil pump tested good but I replaced it and still have the same pressure.
Old Aug 5, 2017 | 05:01 PM
  #24
Well that's just bizarre. I am real curious what's goin' on there. Where is all the pressure going?
Old Aug 9, 2017 | 10:59 PM
  #25
MoparFanatic21
Sorry tour it down 3 times now. Everything is correct the first time the pick up time was dented so I thought maybe that, but I think it would cause it to increase not decrease.
Old Aug 10, 2017 | 08:36 AM
  #26
Restriction in the pickup tube will reduce volume being pumped, which will reduce pressure.
Is the pickup to close to the bottom of the pan?
If all the tolerances are right...... Is there a restriction in the passage going up to the sensor?
Old Aug 10, 2017 | 09:37 AM
  #27
MoparFanatic21
That was when I first ripped into it since then had a new pump and has been tore down 3 times with everything being correct. I'm lost. What you said would make sense I was tired when I wrote that lol
Old Aug 10, 2017 | 09:59 AM
  #28
Are you just running a stock pump? Have you tried a high volume pump? (or higher pressure pump?)
Old Aug 10, 2017 | 10:09 AM
  #29
MoparFanatic21
Can't remember the brand but it is a high volume pump as this beast takes 9 quarts of oil with the bigger pan and filter.
Old Aug 10, 2017 | 10:12 AM
  #30
And all that does is confuse me more......
I can't think of ANY reason your oil pressure should be that low, on a NEW motor. Is your mechanical gauge accurate? Is a plug missing somewhere in an oil gallery? This just makes no sense at all.
