Possible computer problem or wire with bad connection?
Old Sep 17, 2017 | 09:45 AM
  #21
If you suspect the cat may be bad, remove the front O2 sensor from the exhaust completely, and go for a drive. Does it run any better?
Old Sep 17, 2017 | 10:14 AM
  #22
Scottmed1's Avatar
Scottmed1
I will do that, you mean just run it with the sensor out and basically just a "hole" in the pipe ?
Old Sep 17, 2017 | 10:55 AM
  #23
Yep. If the cat is clogging up, the hole will give the exhaust someplace else to go. (and yes, it will be louder, and it will set a code..... )
  #24
Scottmed1's Avatar
Scottmed1
So I ran it without the upstream sensor, no change, still didn't wanna climb the hill(outta my driveway) but funny thing is without the sensor no cel but a when I reinstall it the cel comes back on with the same 2 codes
Old Sep 17, 2017 | 10:56 AM
  #25
Then you have something else going on......
Time to test the TPS, and fuel pressure.
Old Sep 17, 2017 | 05:17 PM
  #26
Scottmed1's Avatar
Scottmed1
I was planning on testing fuel pressure I just need to get a pressure guage but how can I test the throttle position sensor? Other than just replacing it and see what happens. I know it's not a really expensive part but it's starting to add up with all the parts and other stuff I've been throwing at this lately
Old Sep 17, 2017 | 09:06 PM
  #27
Do you have an analog volt meter, or, can you get your hands on one? Check the output wire, should be less than 1 volt at idle. (closed throttle) Greater than 3.5 at WOT.
Old Sep 18, 2017 | 07:34 AM
  #28
Scottmed1's Avatar
Scottmed1
I can borrow one from my boss . I will check it as soon as can this week. Thank u
Old Sep 21, 2017 | 06:53 PM
  #29
Scottmed1's Avatar
Scottmed1
The throttle position sensor is fine. I need to get a fuel pressure tester . Would something like the one in the pic I attached work? Will this tester work on my ram
Old Sep 22, 2017 | 10:12 AM
  #30
Work just fine for gas engines.
